oil pan
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
oil pan
while out looking at my car trying to find out whats wrong with it, see my other thread about codes 14 & 45, i noticed my ooil pan looks dented, like one big dent 4 inches in diameter not some little roan gravel ding but big. can any one show me a photo of a stock oil pan for comparison or tell me about what kind of problems a dented oil pan could cause if any
thanks guys
thanks guys
Car: 1985 Iroc-z
Engine: 355 sbc
if the dent is deep enough, it could have hit the oil pump, none the less, a dent can greatly interupt the oil flow and make the pump work harder.
Taking you have a OEM 5 quart oil pan, go to summit n buy a oil pan.
It steel and its like 24 bucks. Get it, primer it, and paint it whatever color but be sure to primer it.
your back in business.
Engine: 350ci
this is badd *** im glad its not expensive just trouble some, like some many things
th edent isnt to deep but looks not right so when ever i get the time and place to do it i get it cone thanks for clearing up my worrys!
i rode a hyabusa today and **** that thing was fast, to belive cars can go that fast boggles me because that what i have wanted to do, make a fast car but **** i could just get a bike, what a rush, i was lughing so hard it hurt my lungs because i couldnt beath right may have been the speed
the oil pump pick up should be between 1/4 and 3/8 off the bottom of the pan. if the dent isn't that deep i'd suspect you have no problem. most oil pans are dented to some extent like you described.
