engine hard to start
Old Nov 8, 2000 | 09:52 PM
Monkie's Avatar
In the morning when I go to start my car it is hard to start. It will start i just gotta crank it for about 4 or 5 seconds to start. But during the day after it has been running it will start with a turn of the key. Is there anything wrong?
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
Old Nov 9, 2000 | 07:23 AM
Vader's Avatar
Monkie,
When you first turn on the ignition, wait a couple of seconds before cranking to allow the fuel pump to build rail pressure. You should be able to hear the in-tank pump run. If you have a leaking injector or FPR, the residual fuel pressure could be non-existant.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 9, 2000 | 03:44 PM
Monkie's Avatar
Thanks Vader thats the problem I bet. Ill let you know tomorrow if it worked
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
