Aluminum Corvette L98 Heads
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you will need to elongate the 4 center intake bolt holes. also if you have to be emissions compliant, then need to modify the EGR system to the way corvettes were done.
Car: '87 Camaro LT
Engine: 355 L98
you only have to elongate the four center intake bolts if your intake is an '88 or newer. the vette heads never changed to the new bolt angle, even after going to center bolt valve covers. there is no EGR port, vettes got the exhaust gasses out of the manifolds instead.
Engine: 360 HSR
Originally posted by D M N
is the EGR the same thing as the smog pump?? either way i'm getting rid of it and run dual cats
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
I just found some Dart Pro 1 Al heads at summit for 425.95 with similar spects "72cc combustion chambers, 200cc intake runners, accepts 2.02/1.60 in. diameter intake/exhaust valves, angled spark plugs, with valve job only, bare, Pro 1 cylinder head"
They are only $425.95 that how much the corvette heads would cost after porting and polishing them and having a valve job the only wrong i see with them would probably be the custom headers and does anyone know if a LT1 intake would fit with does heads
Fine Print SummitRacing
I would still think hard before spending serious money on replacing Iron L98 heads for alluminum L98 heads. Your only increases would be from the weight loss and compression increase. And I'm not sure the compression increase would really net anything noticeable. The alluminums will more than likely flow the same numbers.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
-Aluminum Corvette L98 Heads
will these bolt on to a L98??
Why wouldnt they ?
Corvettes and F-bodys had the same L98
I second the head change.. there a re better heads for cheaper.
Why wouldnt they ?
Engine: 3.4 DOHC
well a L98 camaro engine and L98 corvette engine arnt exactly the same i mean corvettes have the 4 bolt main and camaros dont i dont know why but they do
Car: '87 Camaro LT
Engine: 355 L98
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
"Will L98 heads bolt to an L98 engine?"
lol, sorry, it had to be said
Yes, they will bolt up fine.
Engine: 360 HSR
are you kidding?? then why do L98 Vette engine cost 900 more then a regular L98
ambainb
Apr 25, 2016 09:21 PM
