Roller Lifter Question
Old Aug 31, 2003 | 11:36 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I think I mixed up the roller lifters in the engine, Is there anyway to find out which way they have to point cause i know they are angled to keep the cam in the enigne. Is there a way to find out so I don't have to buy new ones.
Old Sep 1, 2003 | 12:22 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
um they're not angled and when you set the lifters in the bores, there are holders that hold 2 of them in correctly and then the "spyder" that holds all the plates down
Old Sep 1, 2003 | 04:29 AM
ede's Avatar
ede
you can't put them in wrong, well you could if you really tried, but basically if the fit in the holes, the roller is on the cam lobe and the retainers and spyder fit it's all good.
Old Sep 13, 2003 | 11:37 PM
iggy1991's Avatar
but doesn't the lifter have to stay matched to the lifter hole in the block?
Old Sep 13, 2003 | 11:54 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Nope.
Old Sep 14, 2003 | 10:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not roller ones. They don't wear to "match" the cam like flat ones do. Flat ones will be destroyed by going back on the wrong cam lobes, but rollers don't matter.
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
