Need help with 96 ford explorer(grandparents car)
Old Aug 31, 2003 | 11:59 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
it bascially not blowing out any heat.
the coolant is hot and the temp is up.
What should i look for?
could it be the vent sail?
or heatercore?
but i don't see or smell coolant.
Old Sep 1, 2003 | 05:28 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
check the thermostat...might be stuck open..
Old Sep 1, 2003 | 09:03 AM
Vader's Avatar
Maybe if you found a "Ford Board" they might be able to help you locate a hot water control valve or temperature control door in the ductwork, or a cable/lever in the controls, but it isn't likely going to be anything like a ThirdGen, let alone a GM.
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 8, 2015 01:18 AM
