GM Crate 350 ,HP?
GM Crate 350 ,HP?
I have been talking to other thirdgenner's
about the crate 350 from GM, the version that sells for $1289. It's rated @ 249HP and 304 ft/lbs torque. Does anyone know if it was tested with or w/o headers? How about a four barrel or TPI? Any answers would be greatly appreciated!
How about that myth that we can drop that motor in without changing our little 305 computer?
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I've got the Goodwrench 350 in my 85. It was a huge inprovement over the LG4. I didn't replace anything during the swap. You may have to change some stuff on a TPI though. As for the horsepower, I read somewhere that the 250 HP rating was with headers and aluminum intake, not sure which carb was used either. This is a great engine to start out with. It makes good power and gets good mileage, about 25 highway. If you want to make some more power it is a good foundation. You could go with a ZZ4 or other high performance crate engines. I bought the cheaper crate engine so I can mod it how I like. So if you want just a daily driver it would be an economical choice. If you're going to race maybe go with a ZZ4 or something. It's all up to you. Good luck either way you go.
thats a good engine, as you may have read, lots of car mag's use it as a base engine for their build ups. also... i read in CHP a few months ago that they dyno'd the engine w/headers and an intake, and it made about 230hp, slightly under what was claimed, go figure
SDPC2000 ..
