Points distributor Q...
Old Sep 6, 2003 | 11:47 AM
StealthElephant's Avatar
Car: 87' Iroc
The gears on the points are chewed up (where it would meet the cam) Can I just remove that drive gear and put a diff one on? Will the drive gear off my TPI HEI work on it? It's going into a pre 87 350....I think I read that the newer HEI gears on roller cams could not go on non-roller setups....will any drive gear work? I just go to pep boys and ask for a 350 chevy distributor drive gear and it will fit the points?
Old Sep 6, 2003 | 03:50 PM
ede's Avatar
ede
should be no differance in the distributor gears. the only thing i know of on roller cams and distributor gears is you need a bronze gear on a billet after market roller, not a factory roller. if you aren't sure you can buy replacement gears, or even another distributor.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Out-Cast
Sep 11, 2015 08:03 AM
Jlanz55
Sep 6, 2015 03:05 PM
