What does Dwell meter actually measure ?
Old Nov 11, 2000 | 12:37 AM
voltran's Avatar
Old Nov 11, 2000 | 07:27 AM
ede's Avatar
ede
in referance to points? it measures the degrees of rotation the points stay open as the 8 sided cam (for v8) in the distributor rotates. the high part of the cam opens the points to make and break the eletric connection.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 11, 2000 | 09:37 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You sure about that ede? I've alway thought dwell was the amount of time the points were closed, in relation to camshaft degrees?
If I'm assuming correct, then the dwell time is the amount of chargetime for the coil, in relation to camshaft degrees.
Old Nov 11, 2000 | 10:24 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Wow, its been a while since I've used one of those. Mine is covered in dust. I was under the impression it represented the amount of degrees (which effectively is time) the points were open.
Regardless, the amount of degrees of opening corresponds to width of opening on the points. A dwell meter is easier to use (especially with the GM window on its distributors) than physically setting your points with a set of feeler guages and far more accurate.
You just hook up the dwell meter as per the instructions, open the window and slowly turn the screw with an Allen wrench until your points are at the recommended dwell setting (usually in the 34* range on most GM engines).
Also, remember that if you adjust your timing, that you will affect the dwell setting of the points. This is because the turning of the distributor causes the dwell setting to be affected.
Old Nov 11, 2000 | 02:34 PM
ede's Avatar
ede
no i'm not 100% sure and i can't find anything in my old manuals to tell me for sure.
1st & 3rd
Old Nov 11, 2000 | 03:09 PM
Brent's Avatar
Actually it's the other way around. If you adjust dwell (the points gap), you affect the timing. If you turn the distributor to set the timing you don't affect the points gap.
Old Nov 12, 2000 | 07:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The reason I say it is, I still run point's in my '57 and '59...I know to increase the dwell, I shorten the point gap...and vice-versa.
Guess it's time to pull out the MoToRs and blow the dust off
Old Nov 12, 2000 | 07:44 PM
Vader's Avatar
Voltran,
From one galactic overlord to another, a dwell meter actually measures the duty cycle of an input signal. In terms of breaker points in a Kettering ignition system, the duty cycle (ratio of the time on to the time off) a 50% duty cycle on an eight cylinder engine would equate to 22½° of distributor rotation. Since each complete 360° rotation of the distributor represents one complete engine cycle, the greatest possible angle for each of the eight divisions on the distributor cam would be 45° (45 x 8 = 360). A six cylinder engine could have up to 60° rotation, and a four cylinder would have a 90° maximum.
A typical V-8 target dwell angle is 30°, or a 66% duty cycle. This means that the coil is energized 2/3rds of the time the distributor is moving.
All of these numbers are valid on a single point distributor. Dual point distributors lengthen the angle by closing and opening at different times, in a staggered arrangement.
Since a dwell meter is actually a duty cycle meter, it can also be used to check the operation of ECM load devices like carburetor enrichment solenoids and fuel injector pulse widths. Since the indication is a measurement of the relative on-to-off times of a signal, actual time cannot be calculated, just a relative number. It can still be a useful tool as a go/no-go indicator.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited November 12, 2000).]
Old Nov 13, 2000 | 03:23 AM
Locry's Avatar
so what's the ideal dwell for a v8? i haev a dual points distributor and i don't know what to set it at? what's safe for the coil? the dual point increases dwell time right? can't this be done with a single point?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
AUZ28
Oct 3, 2015 06:28 PM
sahlomonic
Sep 20, 2015 07:15 PM
