What do Vortecs need to take .480'' lift?
Old Sep 8, 2003 | 03:59 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I recently bought a lt4 camshaft and I am purchasing a set of vortec heads within the week. I would like to run 1.6 rockers and get the advertised .480'' exhaust lift from the lt4 camshaft. Would I be able to achieve this with a spring change? If so what springs would you recommend?
Would I have problems with studs coming out at .480'' lift?
Old Sep 8, 2003 | 04:18 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
depends...
Wouldn't recommend it, but I am getting over .490 lift with the heads remaining stock. I just go easy and don't race it that much. I do get on it hard when the time beckons however.
You need better springs, and while you are at it, might as well replace the seals and get a 3 or 5 angle valve job too.
Old Sep 8, 2003 | 04:41 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
I would recommend upgraded springs with screw in studs and new seal...no valve job otherwise you start screwing with a perfect head.
Set the seat pressure as low as possible...you won't need more than that for .480 lift
Old Sep 8, 2003 | 05:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
SDPC sells Vortecs already prepped for .480" lift.
If you get stock heads, upgrade the springs as mentioned. Make sure there is at least .040" more clearance between the guide/seal and retainer than you have lift.
You'll need self-aligning rockers unless you have guide plates installed.
Old Sep 8, 2003 | 07:04 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
just a thought.........i bought a set new vortec heads from jegs and the lift from them would only accept up to a .470 lift....you might want to check them for anything over that.....and as they previously said i would make sure to change the pressed in rocker studs to screw ones......
Old Sep 8, 2003 | 10:47 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I have a set of used Vortecs. I measured the retainer-to-seal clearance.
With the stock seals I measured .540". So allowing the .040" clearance that five7kid recommends, that still leaves .500".
I don't know where Jeg's, CHP, and all those other places are coming up with .465" and .470" being the max.
Maybe they're talking about the stock springs???
Old Sep 8, 2003 | 11:05 PM
Transmission: 4l60e
The heads Im getting could already have better springs I don't know. The motor had the vortec heads and the lt4 camshaft I have in it. I'm gonna do springs and seals at least. I don't know about the screw in studs just yet.
Are stock rockers self- aligning? Im not sure about valvetrain **** really.
Old Sep 9, 2003 | 08:24 AM
82camaro's Avatar
Car: 82 camaro SC
Car craft stuck a set of these springs on Vortec heads to achieve up to 550 lift without any other changes to the heads.
http://www.jegs.com/cgi-bin/ncommerc...63&prmenbr=361
http://compcams.com/whatsnew/NewsDet...ID=-1373872784
Old Sep 9, 2003 | 04:06 PM
Transmission: 4l60e
They put ls1 springs in it? What diameter are they?
Old Sep 9, 2003 | 06:00 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
im pretty sure those are too big, 1.445" diamater
Old Sep 10, 2003 | 06:05 PM
82camaro's Avatar
Car: 82 camaro SC
Too big, I don't know. Just read the article. They put those new springs on vortec heads and the results were good. 550 lift and lighter other 'performance' springs.
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Jorlain
Oct 8, 2015 01:57 AM
monte87cortez
Sep 26, 2015 08:10 PM
anesthes
Sep 21, 2015 10:24 AM
