Shuddering problem(non thirdgen)
Old Nov 13, 2000 | 07:45 PM
foo02's Avatar
Hello, Im having a problem with my dad's Bonneville and you guys are the only place i know that i may find a good answer. What it does is it 'shudders' on acceleration, especially in left-hand turns. Right hand turns it goes smooth. Sometimes it does it straight line. I replaced the hubs and checked the tie rod ends and they seemed to be fine. Any ideas?
Thanks!
~Sp33d~
(sold)1989 2.8l 5-speed RedBird w/ flowmaster, cold air intake, TRW cam. Audio system includes-Cadence component plate 4x6's/Cadence 3way 6x9's,300watt amp to front speakers/400watt to Blaupunkt DVC 12" sub.
Old Nov 13, 2000 | 08:16 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Not sure what type of "shudder" you are experiencing. A "shudder" can be caused by plug wires breaking down apon acceleration, could be the transmission shuddering, might be a driveline issue, but its hard to say.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 13, 2000 | 08:29 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I had a similar problem with a 86 Celebrity I had. Turned out to the the CV joint. It wasn't doing the clicking thing so I didn't ever think it was the joint but it was. If it's not engine related I think that is a very good possibility.
'89 Formula 383 TPI
Old Nov 13, 2000 | 08:38 PM
foo02's Avatar
oh forgot to mention engine runs great I was thinking CV joints too...but the boots looked perfect so i thought id get a second opinion
Edit-i am pretty sure its drivetrain related because it varies with which way i turn
~Sp33d~
[This message has been edited by foo02 (edited November 13, 2000).]
Old Nov 13, 2000 | 09:29 PM
mtx28's Avatar
check motor/trans mounts
Old Nov 14, 2000 | 05:59 AM
Locry's Avatar
could be your power steering pump... my galant used to do that... i traded that galant for the 83 transam i have now... so there...
Old Nov 14, 2000 | 12:59 PM
Bort62's Avatar
Look at the tranny Mount
My camaro used to Clunk around in left turns under load.
TRanny Mount was busted in half.
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Infested
May 22, 2018 11:56 PM
TheJoeY88
Dec 31, 2016 07:30 PM
sreZ28
Aug 14, 2015 07:48 PM
TheJoeY88
Aug 13, 2015 06:51 PM
novaderrik
Aug 10, 2015 12:44 PM
