Fuel filter / O2 sensor
Old Sep 14, 2003 | 06:38 PM
MasterEvilAce's Avatar
Where is the fuel filter located, exactly?? i did a quick check in the rear but didn't quite see it
and is there a special tool for removing the O2 sensor? I have a '87 350 TPI and we have practically no tool that can get it out (some come close.. but no-go) Do I have to remove the exhaust manifold, or something? I hope I don't have to...
thanks
Old Sep 14, 2003 | 07:24 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I know snap-on and mac make o2 sensor sockets.. as for the fuel pump, its in your fuel tank and is a PITA
Old Sep 14, 2003 | 07:26 PM
dans82bird's Avatar
Engine: 302
oh you mean fuel filter its probably somewhere under your car by the framerails, just follow your fuel lines back from under the hood to your tank, your bound to run into it somewhere
Old Sep 14, 2003 | 07:31 PM
So there is a special socket then... thank *** :hail:
Old Sep 14, 2003 | 07:36 PM
dans82bird's Avatar
Engine: 302
You can probably get a cheapie from an auto parts store (maybe). If you plan to keep it forever check this http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
Old Sep 14, 2003 | 07:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is a special socket (7/8" deepwell 3/8" drive with a slot cut up the side of it for the wire harness) that most parts stores carry. They usually run between $15 & $20 depending on where you go. Just ask for the O2 sensor socket and specify that it is for a GM car.
Almost forgot, your fuel filter is located just forward of the left rear wheel and is mounted in a bracket attached to the frame. No insult to your intelligence meant here, so please don't take offense,but use two wrenches when removing the lines from the filter. A friend of mine didn't and had to replace the lines because he twisted them in two.
The Trickster!!!!!!!!!!!!!!!!!!
Old Sep 14, 2003 | 08:24 PM
great advice
Old Sep 15, 2003 | 12:15 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
My car was on a lift for the first time in it's life with me...
and I got to see the fuel filter amoung other things... bits of rust etc....
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
