Throttle Deceleration
Car: 1989 Pontiac Firebird
Engine: 305 TBI
When out of gear with the clutch engaged and only when pressing the throttle (1989 Firebird, 305 TBI, T5), my car will increase deceleration. Any idea why this is happening?
Engine: 305 TBI
I haven't checked the oil level, but it's on my to do list. I had my clutch replaced around March, and I discovered this oddity a month ago. I hadn't revved the engine with the clutch engaged and the shifter in neutral before then, so I'm not sure if it existed before or not.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yeah i know what your talking about mine does...maybe did that i'll take it for a spin and let you know.
Car: 1986 Camaro SC
ok mine doesnt do that anymore, when it did do it my clutch wasnt working properly.
Engine: 305 TBI
I'm not sure if this is related at all, but after driving through some semi-deep water (had no choice...flash flood and had to get home, was slightly above the sidewalk in one area) it's been harder to shift into gears (it was hard randomly before, but now sometimes i have to push hard or push for a while and after a second or two it'll pop into gear). I'm not sure if it's due to the clutch, or the transmission. I really need to check the oil in the transmission but I have a few finals coming up and no time to do it. Any ideas as to what the shifting problem is?
Pac J
May 17, 2020 10:44 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
HoosierinWA
Oct 7, 2015 10:15 AM
