Rear main seal leaking... What should I do?
Old Sep 17, 2003 | 07:45 PM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
My '92 had developed a minor leak (a drop or 2) about 7 or 8 months ago and now it has become worse, leaving a small puddle to the point that I have to check it every couple days. I'd rather not replace the seal. Is there a good seal conditioner or some product that stop a leak from the rear main? I use GTX High-mileage oil, and it has seal conditioners in it which I'm sure helps, so I'm not really sure if an additive would help any. Thanks for any input.
Chris
Old Sep 17, 2003 | 08:53 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
Well, if it leaks a "puddle" any type of additive that would maybe stop that would probably do damage to the oil pump.
Replace the seal and surrounding gaskets, you DON'T have to pull the engine. but u will have to pull the timing cover to be safe when replacing the front seal/to get the oil pan off.
Old Sep 17, 2003 | 09:52 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Yeah I guess I'll have to tackle it that way. Never had to mess with the rear main seal before so we'll see what happens.
Thanks,
Chris
Old Sep 17, 2003 | 09:59 PM
Guest
Guest
Posts: n/a
he isn't talking about the front main he is talkign about the rear main... to replace it your goginto have to remove the transmisson i dont knwo of any other way of doing it
Old Sep 17, 2003 | 11:05 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No additive will even touch a rubber RMS. The additives do work with leather seals (who's seen one?) and rope seals. The dont expand rubber or recondition a craked seal.
You got it easy RMS with an auto trans is a peice of cake just remember to grease the seal before installation.
Old Sep 18, 2003 | 08:41 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Thanks for the input guys.
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
