What are my options for a THIN head gasket?
Old Nov 18, 2000 | 09:31 PM
Jester's Avatar
My compression with the heads and pistons I have is a bit too low for me. I think I can get a few tenths of a point above what I have by going thinner than a standard .038 gasket. What is available, whats the part number, how thick is it, and how much $$$ are they?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Old Nov 18, 2000 | 09:58 PM
scauffiel's Avatar
Hope this will help Jester...
Steve
Old Nov 19, 2000 | 08:52 AM
ede's Avatar
ede
i wouldn't use a steel shim type gasket ,.019 i believe, due to the difficulity of getting the to seal, especially if any machine work has been done to the deck or head.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 19, 2000 | 09:14 AM
Jester's Avatar
That .015 Felpro sounds pretty good, thanksman.
Old Nov 19, 2000 | 07:12 PM
md's Avatar
md
Jester,
I think I’m obligated to try and convince you to NOT use a shim gasket. The only way to make them seal for any length of time in a street engine, and I do mean, “only way”, is if your block deck is perfectly flat and true. The heads also require the same detail. GM used them in past times out of the factory; but then again, everything was “new and true”.
You would be leaps and bounds ahead if you get the block decked to zero or -.005” (piston down the hole). Then you could use the .040” Fel Pro’s that have NEVER failed on me (and I’ve been doing this crap for many, many moons). At zero, your piston will be up .025” more than stock, and that’s the difference between the shim and a “real” gasket.
Mike
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
