Is Lithium petroleum based?
Old Nov 19, 2000 | 03:23 PM
1989CamaroRs's Avatar
im tryin to figure out if i can use it on my spark plug wires, lithium grease that is
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
[This message has been edited by 1989CamaroRs (edited November 19, 2000).]
Old Nov 19, 2000 | 03:41 PM
ede's Avatar
ede
why? if your wanting to seal them buy a spray can of silicone and use it. if your wanting to seal the boots use the "grease" made for that.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 19, 2000 | 05:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
ede's right, use the stuff designed for the job.
Lithium is an element, and it is used in soap form as a thickener for grease. It is also used to treat bi-polar conditions ("Chill out, you manic!).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Nov 19, 2000 | 05:47 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Actually, I think the grease you want for electrical connections is Di-electric Grease, not Litium (which may be a componenent) of Di-electric Grease.
Litium Grease if very clingy and sticky. It is good for latches, hinges etc where it may be exposed to the elements and won't break down or attract crud.
Di-electric grease (also white) is specifically made to resist electrolysis and stops that corrosion like you see occasionally on battery terminals. It also conducts electricity. Look for di-electric grease, not lithium grease.
Old Nov 19, 2000 | 09:42 PM
five7kid's Avatar
Actually, Glenn, dielectric means it does NOT conduct electricity. If it was a conductor, you wouldn't want to put it on your plug boots!
The Permatex tube I have says it contains silicone, but doesn't say anything about lithium.
Again, lithium can be used as a thickening agent (soap) in either petroleum or synthetic greases. I've never heard of it being used in silicone products, but I don't know everything...
Old Nov 19, 2000 | 09:44 PM
i wasnt talking about sealing or cleaning. im making a custom set and i just wanted to know if that was ok to use for putting the boots on
Old Nov 19, 2000 | 09:52 PM
Vader's Avatar
Just for reference, lithium is a mineral. Use silicone dielectric grease on plug boots, weatherpack connectors, etc.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 19, 2000 | 10:01 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Silicone dielectric grease has a high resistance, but is an adequate electrical conductor when used to lubricate electrical connections due to its thin coating between the contacts, and is very good at keeping water and corrosion out. I use it in all of my electrical connections under the hood. All of the dielectric grease that I have used is clear, but I'm sure that it's possible that it's sold in white also.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 19, 2000 | 11:04 PM
Car: Death Mobile
Engine: 666 c.i.
I actually went to look at my tube to see what color (if it any it was), it is basically clear with a slight opaic tint.
Regardless, I fully agree with Jim and use it on ALL of my electrical connections, especially where there is any risk of exposure to moisture. I also put it on the inside of the boots and on the threads of the spark plugs. Makes it easier 30,000 miles later to remove them.
Old Nov 20, 2000 | 11:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
89CamaroRs, you want to use this stuff to slide the boots on, and that's it, right?
The Di-electric stuff works fine for this. Hot Rod used WD-40 in one of their articles to slide the boots onto the wires, but I'm not so sure about that. Grease/oil usually works its way into the insulation of spark plug wires, and causes "spark leak". Seems that WD-40 would be the same as grease/oil.
I've always used di-electric when building my MSD wires, use enough, and the boots slide on really easily.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
