How difficult is it to remove upper bellhousing bolts?
Car: 92 Z28
Engine: 357 TPI (L98)
I'm not planning on pulling my engine anytime soon, but I'll have to at some point for various reasons, and I was wondering...
How difficult is it to get to the upper bellhousing bolts? It seems nearly impossible when I think about it, but I'm sure you guys know the best way. Is there an optimal combination of tools to do it easily? Can any of them be removed from the top of the engine compartment (as opposed to being underneath the car)?
Thanks guys.
Thanks guys.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
When we pulled my tranny out 2 weeks ago, my friend got all the bellhousing bolts from inside the engine bay.
just reached down behind the motor and undid the bolts.
Originally posted by jamesbob02
Awesome. Anything special required or just typical ratchet/wrench combos?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i had just mentioned thins on another 3rdgen board i goto...
http://www.3rdgen.org/bb/showthread....threadid=21318
just undo the tops before you go under the car, then support the tranny and undo the lower ones.
Originally posted by MrDude_1
you already need to pull the distrib... just do that first, stuff a rag in the hole.... then use a wrench and undo the bellhousing bolts FROM THE TOP!
its so easy that its one of thoes "duuuh why doesnt everyone do it this way?!" kind of things...break them loose with the wrench, then spin them out with your fingers..... it makes it soooo easy.. just get under the car, support the tranny and undo the other ones... no wobbly extention needed..
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if u do plan on goin from the underside to take the bolts out the best thing to have is a 3-4' extenstion. i did a motor swap on an 85 monty at work, i was helpin the master tech (i did a pretty big chucnk of the work) and the 3-4' extenstion is great
just a matter or the correct tools for the job and they're as easy as any other bolt on the bell. i use a 3' extension 1/2 on drive end and 3/8 on the socket end. impact wrench and a flex socket and it's no problem at all to get
Car: 1985 Iroc-z
Engine: 355 sbc
Originally posted by dans82bird
I use 2 long *** snap-on 3/8 extensions I have with a swivel socket or a u-joint/socket and turn it with a long handle ratchet.
My friend has a wrench that is bent n he reaches up n cracks them from underneath but the 3/8 ext... is the way to go I think.
the hardest part is getting the socket on the bolt head but once u crack them usually u can turn them with your fingers.
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
its alot easier from under the car if you just take the tranny off the belhousing first.
i usually take the motor and tranny out as a unit though.......its just easier
Car: 91 Camaro Vert
Car: '82 Z28
Engine: 350HO
Transmission: M4
either manual or not, just drop the tranny crossmember bolts, put a jack under the tranny, lower it, get about 9-12" of extnesions, and a u-joint, and in 5-10 min your done. not all that hard.
and for those with a manual you can take the bellhousing off of the tranny, because you are going to have to do it anyway to get it back in the car.
because it is much easier to line up the input shaft, when the bellhousing is already bolted to the motor.
Car: '91 Camaro RS
Originally posted by Zepher
How do I take the tranny off of the bellhousing first? I don't have a manual tranny right now.
lol
evilstuie
Jan 9, 2020 08:29 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Eric-86sc
Apr 3, 2016 03:52 PM
383backinblack
Aug 15, 2015 06:36 PM
