Name that sound
Old Sep 27, 2003 | 07:58 PM
jiggajiveturkey's Avatar
Car: 88' Firebird
Engine: 2.8L
Name that sound
Sometimes during turns my car makes a loud rumbling sound. Obviously this seems to point to the power steering, however the fluid level is good and there are no other signs that the pump is going bad. Another puzzling part of this is the sound seems to be comming from the passenger side no matter which way i am turning. If anyone has any ideas that would be great, thanks.
Old Sep 27, 2003 | 08:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Alignment good?
Old Sep 27, 2003 | 08:22 PM
Car: 88' Firebird
Engine: 2.8L
Wheel is strait and it doesn't pull. Had the back tires replaced not to long ago; the front tires will need to be replaced with in the next few mths. Could it be a tire issue?
Old Sep 27, 2003 | 08:26 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Sounds like a wheel bearing to me. Does it do it both ways when your turn or just one way?? If it only does it when you trun right it is the left side, and if it does it when you turn left, then it is the right side. OK just re read your post. Both ways, most likely ned to do both sides then. HTH?
Old Sep 27, 2003 | 08:31 PM
Leahs88irocz's Avatar
Car: 1988 iroc-z baby! :o)
Transmission: soon 2 be replaced.
maybe ur tierods......my car was doing something like that....i replaced my tierods....and everythings fine now.
just a thought.
Old Sep 27, 2003 | 08:48 PM
Car: 88' Firebird
Engine: 2.8L
Wheel bearing makes sence, I will check that and the tierods tomorrow and let you know... Thanks
Old Sep 27, 2003 | 08:59 PM
RP1987GTA's Avatar
worn tires that are cupped on the edges can make a hell of alotta noise in turns
Old Sep 28, 2003 | 12:50 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
is the sound louder the harder you turn? Is so check your idler arm bushings. Just a idea.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
