weird heating problem
Old Nov 23, 2000 | 11:38 PM
bleak's Avatar
When I turn on my heater (or defroster, or anything) I get nice hot heat out of the defroster vent but I get COLD COLD COLD air out of somewhere under the dash!
Turning the little fan speed **** does changes nothing. Moving the selector to any option always gives defrost.
88 firebird 2.8
Old Nov 24, 2000 | 10:57 AM
bleak's Avatar
bttt, please
Old Nov 24, 2000 | 11:02 AM
bleak's Avatar
oh, sorry.
My question is, how can I make it stop blowing cold air? That really sucks when it's 40 degrees
Old Nov 24, 2000 | 11:55 AM
Vader's Avatar
Bleak,
If the heater core has been replaced, it is possible that the plastic case was not reassembled correctly. This could allow for air leakage into the passenger compartment. It's also possible that the air recirculation damper is partially stuck in the open position. This is the door that opens when you turn to "MAX AC" and allows some air from the passenger compartment to recirculate through the evaporator and heater cores. If the door is partially open, some cold air from the cowl can blow in at the passenger side footwell as well as following the "normal" path through the cores.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
CORV3TT3
Aug 23, 2015 11:26 AM
sreZ28
Aug 14, 2015 07:48 PM
