valve spring installed height
my springs are suspose to have an installed height of 1.850. most of the intakes run around 1.95 and the exhaust at 2.050. that makes for .2 in shims. that seems a little much to me. any thoughts or ideas? thanks
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
Ed,
If my memeory is correct, most of my SBC springs install at 1.71" height. If you measure the spring only (not the retainer height) the stock intakes are 1.71" or 1.745". Going to 1.85" springs should require longer valve stems and/or deeper spring seats.
I could be off, though. It is a little cloudy tonight...
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
.2 is almost a 1/4". That's alot. I can only come up with suggestions. The spring manufactures installed height is recommended for best spring performance. Too tight and spring bind can occur. Too much installed height and seat pressure is decreased. The springs themselves won't affect the installed height so any number of these choices can be the problem.
Measuring from the wrong location as mentioned by Vader
Seats are cut too low
Valves are too long
Wrong keepers (You can change installed height by just changing the keepers) This is usually done when installed height is too low and you need to raise it. It's possible you have these raised height keepers.
Also make sure the keepers and retainers have the same angle. 7 and 10 degrees angles are available. I don't know if they can be mixed but if 7 degree keepers are used with 10 degree retainers, I suppose it could give a false installed height. (Also a good way to drop a valve)
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Valves are too long
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
as always i tend to try to save on my typing. the springs are lunati 1.5 dia. lunati says to install then at 1.85. useing lunati retainers, no rotator or any stock parts i'd have to shim over .2 on the exhaust. i was wondering if there is a retainer made to reduce installed height or something else so i don't have to shim so much. the springs i'm useing are the ones lunati recommends for my cam. if you can't tell i'm a die hard lunati user.
1st & 3rd
1st & 3rd
i should add i'm useing stock height manley pro flow valves. since they're stock height that shouldn't really change anything, but i thought it was worth saying,just in case.
1st & 3rd
1st & 3rd
Ed,
All Lunati should be a good thing. The components should be designed to work together well - no guesswork. If the Manley valves are Race-Flo 11565/11566, they should be at stock height for the grooves.
Your extra information helps - since you aren't installing rotators, the spring height would be increased on the exhaust side. The lack of spring oil shields would also allow a bit more installed height on both sides.
I take it this is all on the six-cylinder 350, whick has a stock installed height spec of 1.69" - 1.71" on both valves.
Later,
Vader
Later,
Vader
damn vader about spit my coke all over the monitor, 6 cylinder 350. yeah it is the 6 cylinder 350. i try not to say that too much because of all the flames i get for running a six. thanks for the help everyone. i'll make a few phone calls and see if i can find anything else out about my set up.
1st & 3rd
1st & 3rd
sailtexas186548
Aug 26, 2015 03:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
