Problem with starter gear.
Old Oct 1, 2003 | 10:59 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
Okay so I am doing the auto to t5 swap. I pulled off the flex plate and when I went to put the fly wheel on I noticed the gear for the starter was all pushed back inside the starter housing, now it doesnt make contact with the flywheel. I tried pulling the gear foward with a screw driver but the second I let go of it the gear springs back into the housing. Is there a way to fix this? Is this normal?
Old Oct 1, 2003 | 11:55 AM
Z28Clone's Avatar
yes it is normal. when starter motor is engaged, (turning the key) the centripital (sp) force compresses the spring and the gear comes out to touch the flywheel.
Old Oct 1, 2003 | 01:16 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
okay thanks alot, I was kind of hoping that is what it would do, I was worried becasue I was sure it was the starter gear was meshed with the flexplate gears before i removed it. thanks alot
junkcltr
Aug 2, 2019 11:12 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
92camaroJoe
Aug 13, 2015 06:07 AM
