Where do I get the plastic vacuum piping??
Old Nov 27, 2000 | 04:03 PM
sguy30's Avatar
I have an 87 IROC 5.0. Some of the vacuum piping broke during a rebuild. This is the hard plastic type the connects up the EGR etc.. The dealer says the stuff is discontinued, so what do I do??
Old Nov 27, 2000 | 04:23 PM
R.O.B.'s Avatar
Just get some rubber vacuum hose and put it over the plastic hose. I may not look the best, but works just fine.
Rob
'86 TA 305 TPI
Old Nov 27, 2000 | 07:13 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
the 3/16 x 2" vaccume hose connector works great for putting those hard lines together
you can find them in the motormite section at pepboyz
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle, 4 wh. disc brks.
Old Nov 27, 2000 | 07:51 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I broke some of the same stuff on my fuel pres reg and went to parts america and there it was in rolls of like 10 feet.
I seriosly think you should be able to find this stuff at a parts store and if you are lucky they will have the elbows too.
James
88 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
no MAF screens, no cat, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
homemade ramair.
Old Nov 27, 2000 | 09:21 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Advance Auto has it as well, I seen it yesterday.
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Holley AFPR
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
gta892000
Aug 11, 2019 11:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Camaro_383
Sep 11, 2015 11:28 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
