plastic radiator tank repairs ?
Old Nov 27, 2000 | 02:42 PM
gruNT's Avatar
Car: 86 TA
folks,
just pinpointed the sudden cause of my overheating - a small (but sure to grow) crack in the top right plastic side tank of my stock aluminium/plastic radiator. Under pressure it opens a little and coolant sprays out.
Is there a successful way to repair a crack in a plastic radiator tank (epoxy/melt with hot solder iron/whatever ?????) or can a radiator shop repair it or am I llloking at a new tank/radiator ? I'll be ringing a radiator shop later today when they open to see what they can do, just wnated to know if anyone has ever done it themselves - a lot easier than pulling the whole tank out.
ciao
gruNT
near stock 86 LG4 WS6 T/A
Brisbane Australia
http://web.one.net.au/~grunt
Old Nov 27, 2000 | 02:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The plastic tanks are designed as throw-away units. They dont repair them, just replace them.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 27, 2000 | 03:01 PM
Yarnboy's Avatar
You will thank me.. http://wwwradiators.com is the best site..one of the best companies I've ever bought something from..seriously. 134 bucks for a new, better, skinnier radiator. EASY to install..flushing the system is annoying and messy but thats the only part that isn't a breeze.
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Groove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.68, 60 ft. 2.17, 1/8th mile 9.4
-Best MPH 93.9
Old Nov 27, 2000 | 05:41 PM
amagin86's Avatar
yeah, i tried to fix mine when it cracked and it just cracked again. i bought one from autozone (i hate 'em but it was cheap) for about $125 manufactured by GDI
clem
The world is full of stupid people...and I am no exception.
'83 Z28 5 speed (regrettably with T-tops)
'83 Z28 No T-tops (regrettably automatic)
Old Nov 27, 2000 | 06:16 PM
gruNT's Avatar
Car: 86 TA
see, the reason I'd like to repair first then buy a new one later is they're Au$620 over here - I need to save up - just spent $750 on the air con last week ((
ciao
gruNT
Brisbane Australia
Old Nov 27, 2000 | 10:13 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
That is quite steep, but there really is no alternative. The plastic that they are made from is a fiber or glass filled thermoplastic, which is very difficult to repair because of the fill, and the high melt temperature of the thermoplastic. I have repaired the polyethylene coolant resevoirs before, but they are a lot easier to work with, because PE melts at a much lower temperature.
If you couldn't tell, I work with plastics for a living!
Good luck.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Nov 28, 2000 | 08:20 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I tried replacing a side tank once... followed all the directions to a T, and used a new gasket- the thing leaked at the gasket. A radiator shop should be able to do it for you.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 28, 2000 | 06:50 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
i know exactally whatcha mean.. happened to me before, i tried to patch the crack with some ghetto j-b weld.. that worked for about a week.. decided to take it to a rad shop.. did some pricing, for like 40 bux more i went to advance and got a new rad..
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
Strick1
Sep 6, 2015 10:38 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
