Funny 400
Old Oct 8, 2003 | 09:44 PM
soon2B_best91RS's Avatar
Funny 400
not quite sure why but the piston will never come up flush with the top of the block throughout the stroke, the highest is comes up is like 3/16 to 1/4 from the top, what gives?
Old Oct 8, 2003 | 09:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Wrong pistons for the rods being used?
Old Oct 9, 2003 | 06:22 AM
ede's Avatar
ede
most pistons will be .030 give or take a little in the hole. 3/16ths is a bit excessive. just about have to be wrong piston/rod combination
Old Oct 9, 2003 | 02:14 PM
what do you think i should do to go about solving this problem?
Old Oct 9, 2003 | 02:31 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
get new pistons or rods. Sounds like you have stock 400 rods and pistons for a 5.7in rod 400.
Old Oct 9, 2003 | 06:32 PM
supercharge it?
Old Oct 9, 2003 | 09:05 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I like the way soon2be thinks!
Old Oct 9, 2003 | 09:55 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
install the correct parts, or just laugh at it since it's a funny 400.
Old Oct 10, 2003 | 12:21 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
The difference in compression height (centerline of wrist pin to the top of the piston) between the piston for the 5.7" rod and the piston for the 5.565" rod is .135". If that's approximately what your seeing then you do have the wrong piston for the rods your using. Personally I would go with the 5.7" rod. You can get them for about $120 reconditioned with clearanced Milidon rod bolts from http://www.dirttrackthunder.com
Go to the Online Catalog, choose connecting rods and Make: Chevy. They are on the second page. Scroll down 'til you find the 5.7 clearanced rods.
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
