You who are running 400's or long stroke small blocks.
Old Oct 10, 2003 | 10:33 AM
2laneblacktop's Avatar
I just wanted to know what kind of rpm's everyone is winding out to on the strip or where ever? If you are over 6000 what kind of internals are you running? I know there is alot of elements that determine where you make your power, but I am just curious to know. I run a 400 and i run it to about 6000k.
Old Sep 21, 2004 | 03:12 PM
MustangMuncher's Avatar
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
Obviously too much rpm.....
Old Sep 21, 2004 | 04:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Completely depends upon the set-up and combination.
One particular 383 of which I'm aware shifts at 6500 and goes through the traps here at 6800. Lower elevations, 7000 (Las Vegas) to 7200 (Pomona) RPMs.
Old Sep 21, 2004 | 07:37 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
4700 rpm
Old Sep 21, 2004 | 07:40 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
much over 6500 poses some problems for 3.75" stroke
Piston speed in feet per min exceeds 4000 (which is traditionally hard on steel rod motors). The peak hp on my 400 is about 6200. I will probably turn it 6500 or slightly higher.
Old Sep 21, 2004 | 10:20 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have a 406 that I have turned 7000 rpm once but usually I let it shift on it's own at 6200. My internals are stock crank, H-beam rods and forged pistons.
Old Sep 22, 2004 | 05:18 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I shift at about 6200rpm. Eagle forged rods and crank. JE forged pistons.
Old Sep 22, 2004 | 06:24 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
We gear the 410 SBC (3.800 stroke, 4.155 bore) dirt modified car 7200-7800 with a $500 Scat crank and a $600 dollar set of Carrillo rods, JE pistons.
I turned my 383 3.75" stroke $225 Scat 9000 crank with $200 Eagle LW rods, SRP pistons, to 6800 many times. I have it down to freshen it up after 17k and a couple hundred hard passes in three years. Nothing broke or bent that I can tell.
Old Sep 22, 2004 | 08:11 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
SMasterson: I see that you live in Evansville. Do you race at Haubstaudt? (spelling)
Old Sep 22, 2004 | 09:34 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Very much depends on combination. The 388 in my car all stock bottom end with cast crank, X beam rods with ARP bolts, and KB hyperutecs i have taken it to 7K for my all out fast passes and the shop that built it, built the motor for mud packing and said it'd live a long time at 7K-I just dont feel comfortable with that. When racing I shift at 6000 and used to cross the traps at 6800-taller tires dropped me to 5900-6000 depending on air, best part I only lost .04 shifting at 6000 over 7000K. short shifted motors will live a loong time.
Truck on the other hand is shifted at 6600 and traps at 6500-needs more rear gear since peak hp was made at 6800 on the dyno.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
