Help...Timing Adjustment Procedure?
Old Dec 2, 2000 | 07:12 AM
BirdRacer's Avatar
This topic was originally "Cold Start Injector", but I've got a new question. What is the procedure to set the timing on a '87 GTA, LB9 305 / 700R-4? I read on another site to jump the A&B terminals on the ALDL connector (diagnostic mode) to set the base timing. Now I have just read to disconnect the brown/black striped wire next to the heater box/fan housing. I'm afraid this may have been my problem all along.
'80 Firebird
355 c.i. Chevy (built)
8.39 E.T. (1/8 mile) Altitude Corrected - 8.27
In the process of being rebuilt and getting 7-second-ized
'87 GTA
Stock LB9 5.0 / 700R-4 / 3.42 gears
T-Tops
Old Dec 2, 2000 | 09:14 AM
Vader's Avatar
BR,
The ALDL jumper procedure is used on older ECMs and some V-6 and I-4 engines to set base timing. Your TPI uses a bypass connector in the EST system to set base timing. There should be a VECI label under the hood describing the adjustment procedure, and it should look like this:
The bypass connector should be disconnected and the base timing set to the specification. Reconnect the bypass connector and you're set. The connector should be found here:
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
