OEM Roller Lifter Questions
Old Oct 12, 2003 | 03:09 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I've heard that you can reuse the stock roller lifters with a performance cam as long as they are not damaged. The one's I have are from my stock engine and have 185,000 miles but I had them Vat cleaned and they look fine. Should I use them?
Is there any difference between my lifters and the ones GM uses in there crate engines. When I was browsing my GM catalog I noticed that the new rollers are a "second design"with a higher spring preload. What does this mean? Are mine the second design? Or are mine similar to p/n 5234890? I am going to be using the LT4 hot cam and I need to know if I should get new lifters. Thanks
Old Oct 13, 2003 | 05:10 AM
ede's Avatar
ede
i've reused oem roller lifters without any problems
Old Oct 13, 2003 | 01:12 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
So have I but they only had 7k miles on them.
Old Oct 13, 2003 | 03:13 PM
kevinc's Avatar
Car: 1982 Z28
I reused the 90 K-mile OEM lifters in my L98 during the rebuild, worked fine with my HOT cam for 3 years, ran 13.2sec @ 102mph and made 287hp/363tq. Replaced unnecessarily during an intake swap, big waste of $$. If they're quiet, and the engine makes steady normal vacuum, and the're not damaged in any way, they're fine.
Old Oct 13, 2003 | 03:35 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Should be fine if not damaged or making tapping noise.
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
