Could a bad adj. TV cable cause detonation?
Old Oct 15, 2003 | 01:26 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hello,
I'm fixing a detonation issue in a 2.8 V6 by spark advance changes into the eprom.
The last week the car had audible detonation, pinging and retard due to knock.
This week the detonation went out and retard is 0 º.
But, the only job in the car the last weekend was the TV cable adjustment (it was about 1/3 inch misadjusted).
Some relationship between detonation & TV cable adj.?
Or it was a dream?
Any one knows?
Thanks in advance,
Denis V.
Old Oct 15, 2003 | 01:29 PM
ede's Avatar
ede
no
Old Oct 15, 2003 | 05:01 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The only possible thing I could think of, is if the tranny shifted way to early, it could cause pinging, but once the RPMs got sweet, it'd make no difference.
You know, like nailing it in a manual tranny car in high gear, going 30 mph.
Old Oct 15, 2003 | 06:06 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
An improperly adjusted TV cable will not cause pinging, only change shifts.
8Mike9 makes a good point though, however you'd need to be very boggy to make it ping.
Old Oct 16, 2003 | 07:20 AM
Denis.V's Avatar
Axle/Gears: No idea
Hmmm, I re-check the test.
The main problem was in the following range:
2.000 - 2.400 RPMs
70 - 85 kpa (MAP)
Tº = 86º C and up (187º F)
Vehicle speed: 20 - 40 Kmh (13 - 25 MPH!)
Acceleration mode.
MM2Robinson
Oct 1, 2017 09:16 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
