Do I have to use Self Align RR????
Old Oct 21, 2003 | 03:44 PM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
Hey guys I have vortec heads sitting in my shed that goes with my car when sold I have a guy who has 1.7 RR's but the 3/8 none selfalign can they be used with the vortec heads why or why not? my vortec heads have the .550lift springs 3/8 screwin studs for use with guideplates...
Old Oct 21, 2003 | 04:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes you can use non-self-aligning rockers on those heads, if and only if you also use guide plates.
As far as lift limits and whether those rockers designed to fit some other engine move the push rod so far in toward the stud that they hit the inside of the hole, you're on your own.
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
If you have the guideplates then yes you can use non self aligning rockers...all they do is eliminate the need for guide plates.
Old Oct 21, 2003 | 04:41 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
The rr are for stnd small block chevys, there 1.7fully roller. It would bring my cam specs up to .496/.512. the springs on my head can head up to .550... so i think i should be fine, and i would be getting the rockers at a complete steal... i just need to pick up guide plates and heattreated chromemoly pushrods, not a big deal..
Old Oct 22, 2003 | 02:50 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
you will need the guideplates as mentioned above. you will probably also need to open up the hole in the head that the pushrod goes through since the angle of the push rod changes with the 1.7's it will probably hit the side of the hole.
Hodge
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
