Coil Relocation, where did you put it?
Old Oct 22, 2003 | 11:52 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Hey Guys
Well my nitrous solenoids have now claimed the place of the stock coil, so I need to relocate it. Where have you put it? I'd like to keep it as close to the dist. as possible. My concerns are:
1) Drilling in the firewall, is there anything you'll hit if you drill through the firewall in particular?
2) Water; I suppose the coil isn't in the best location stock, but I'd like to keep it away from moisture (I live in the desert so this isn't such a big concern)
Pictures would be awesome!
Tony
Old Oct 22, 2003 | 01:25 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I made a bracket from stainless & mounted it on the firewall lip
Old Oct 22, 2003 | 03:42 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
What's the issue with being close to the dist, wire length? Just curious, I've always tried to get it somewhere cool to reduce the amount of heat on it. We all know the effect of heat on elec. components! (premature failure, and reduced performance) right?
I could be off base here, but that's what I've allways been taught. Thanks
Old Oct 22, 2003 | 04:39 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I too thought it was best to keep the coil as close to the dist. as possible. Here is where I put mine. So far, so good. I do still have problems with coil interference with the mag pickup wires.
Attached Thumbnails Coil Relocation, where did you put it?-newest-engine.jpg
Old Oct 23, 2003 | 08:04 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
I want those valve covers!!! Can I buy them somewhere or am I going to have to steal yours? I've never seen any center bolts like that!
Old Oct 23, 2003 | 09:22 PM
johnsjj2's Avatar
Car: 1991 Z-28
I bought those off of eBay for $115 with the breathers. Scoggin Dickey has them at $185 w/o breathers. They do really set off the engine. I really like them.
Old Oct 24, 2003 | 04:29 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
No bracket just bolted true the angled part of the firewall.....
Old Oct 24, 2003 | 04:33 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Resistance in a wire is directly proportional to length and resistivity of the material and inversely proportional to the cross sectional area of the wire. Longer length, higher resistance. Higher resistance, less current is going to get from the coil to the distributor. I'm not sure if it's enough to matter, a lot of guys run Jacob's ignitions with long a$$ coil wires, but that's the notion behind that.
Old Oct 24, 2003 | 05:36 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Dam man! All those big words! U must be a college grad or something. I think what your trying to tell me is, The longer the wire, the more resistance. The more resistance, the slower the current travels, right? So I'm figuring as long as the coil wire is shorter than the spark plug wires, It wouldn't make that much difference especialy if your using a 40-50,000 volt coil. Isn't that why they make 8mm low resistance wires? On my Javelin I used to race, I had my coil mounted off the fender well because I thought the benefit of keeping it cool as possible would outweigh the length of the wires. The coil wire was still shorter than the plug wires as I had a front mounted dist (like fords). Doesn't heat cause higher resistance also? Don't get me wrong Or think I'm being sarcastic. I just hate to think I've been wrong all this time! I just want to do it right! Thanks!
Q and A's 1: what hood are you running? (doesn't look like a stocker would close on that)
2: What's the big bracket in the forground?
3: where'd ya get the cool look'in valve covers?
Old Oct 24, 2003 | 06:30 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
http://www.sdpc2000.com/cart.asp?act...744&pid=123731
http://store.summitracing.com/partde...t=SUM%2D440336
http://cgi.ebay.com/ebaymotors/ws/eB...category=33627
Old Oct 24, 2003 | 09:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
No, what he's telling you is what he said...more resistance=less current...not slower, electricity still travels at the same speed.
92camaroJoe
Jul 29, 2023 07:57 PM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
