388ci stroker wont start...
Old Oct 22, 2003 | 07:20 PM
LiveRound's Avatar
Car: 1984 Z28
Engine: 388 Stroker 10.5:1
Transmission: th350 Full manual VB
Ok, heres my problem, my car wont start unless i have atleast 25 degrees of base timing... but if i leave it at 25 degrees it'll ping at half throttle so i have to knock it back to 10-12 degrees.... and i run 93 octane....is there something wrong with this lol.... having to open the hood before i start it everyday have become more than a lil anoying.... Any one ever have this problem...?
Will
Old Oct 23, 2003 | 01:52 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
run higher octane?
Old Oct 23, 2003 | 01:57 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Geez, how much compression are you running?
Old Oct 23, 2003 | 05:21 AM
ede's Avatar
ede
my first thought, or two, how much compression, outter ring slipped on dampner, is the cam straight up?
Old Oct 23, 2003 | 10:13 AM
LiveRound's Avatar
Car: 1984 Z28
My compression is listed in my info.. lol 10.5:1 and the cam was degreed. I asked some other people and they said vortec heads dont like alot of timing.... so who knows.
Will
Old Oct 23, 2003 | 11:41 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Originally posted by LiveRound
My compression is listed in my info.. lol .
Will
Are you saying we're seeing things or something?
Old Oct 23, 2003 | 08:40 PM
LiveRound's Avatar
Car: 1984 Z28
huh? no i just said the compression ratio is in my info on the left side of the screen..
Engine:388 stroker 10.5:1
Old Oct 24, 2003 | 12:22 AM
mw66nova's Avatar
Engine: 7.0L
that really is kinda alot for a iron headed motor on pump gas, maybe running some octane booster in it just to see if it fixes the problem is in order.
Old Oct 24, 2003 | 01:21 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
how about some air plane fuel? that crap's around 112 octane over here... ran it in my car, no probs
Old Oct 24, 2003 | 08:08 AM
mw66nova's Avatar
Engine: 7.0L
i wouldn't run more then sunoco racing fuel or some vp.
Old Oct 24, 2003 | 12:37 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Wow, that is to high of cr for iron heads. Knock it down with a thicker head gasket, remove a lot of the timing advance and set initial timing to where it's needed, or plan on running $$$ high octane. 10:1 is pretty much the limit on iron heads and 93-94 octane with minimal timing advance, especially on hot days.
You can minimize the iron head/high CR ping with reverse cooling, or an extreemly cold stat, but that's a whole new can of worms...
Old Oct 24, 2003 | 02:05 PM
smithtc's Avatar
What is the dynamic compression ratio of the engine?
Edit: And other specs...? (intake, exhaust, gears, weight of vehicle, camshaft details, head mods, block mods, etc.) Any information that might help.
10.5:1 compression can be run with 93 pump octane. Some argue that 10:1 to 10.4:1 is the limit area, however...
Old Oct 24, 2003 | 07:07 PM
LiveRound's Avatar
Car: 1984 Z28
uh.... whats a dynamic comp ratio? and i run 94 octan normally.. im gettin aluminum heads this winter, im saving the $$ as we speak. i was just curious, but now that i think of what you guys have said it kinda makes more sense.
but hey w/ the setup i got goin i make 350lbs/ft of torque at 2500RPM and 300hp @ 5500rpm... these specs are at the wheels i dont know what it does at the crank. i kinda wish it was more... but i suppose with some aluminum heads that can be achieved.
Old Oct 24, 2003 | 07:19 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
10:5 is fine with iron heads and with it properly tuned. My motor doesn't ping at all, 10:25 with iron heads and NO tuning whatsoever. I run 93 octane.
Did you line up your distributor correctly when you installed it? Also as previously said, I wonder if the outer ring on the balancer slipped.
Old Oct 24, 2003 | 07:22 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Get the #1 piston at TDC & make sure it agrees with your timing mark. You should not experience pinging if everything is set correctly.
Old Oct 24, 2003 | 09:46 PM
smithtc's Avatar
http://cochise.uia.net/pkelley2/DynamicCR.html
Edit: Check out the Nov. issue of Popular Hot Rodding on the stands. Nice article written by David Vizard..."The Power Squeeze: Maximizing the compression ratio delivers more bang for the buck than you can imagine."
Should clear up a lot of misinformation that you sometimes get from people on these boards, as well as others.
83RDRACR
Mar 26, 2016 08:13 PM
Nervous2
Oct 8, 2015 10:53 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
JSDaddy189
Sep 26, 2015 03:50 PM
