Which Airfoil? Holley or TPIS????
Old Dec 6, 2000 | 11:53 AM
a1987formula350cu's Avatar
They are the same price but the TPIS looks more durable and the Holley looks like it will make smoother air flow...Which one>???
1987 Firebird Formula 350[*]Stock except...[*]Cragar Street Stars
My Car Website w/ Pics
fyrebird350@hotmail.com
AIM/AOL: FIREBERD350
<<<<---THIS CAR IS FOR SALE(only 49k)--->>>>
Old Dec 6, 2000 | 03:11 PM
Blade's Avatar
I think they're all the same Get the cheaper one... SLP
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 12.9@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Old Dec 6, 2000 | 03:22 PM
theformula's Avatar
Agreed
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Old Dec 6, 2000 | 03:28 PM
Dan87IROC-Z's Avatar
I got mine from JET, it was only $48.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 6, 2000 | 06:42 PM
Mo's Avatar
Mo
I dont know if either of those is plastic, but I dont like the plastic ones for some reason, they look cheap or something
Old Dec 7, 2000 | 02:14 PM
Where can I find the SLP or Jet ones?
Old Dec 7, 2000 | 08:32 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Goto www.slponline.com its only 26.95 right know I just ordered mine.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47
Old Dec 7, 2000 | 09:36 PM
Vader's Avatar
87,
You might as well spend as little as possible. My hand-hewn aluminum model makes zero net repeatable power gain.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 8, 2000 | 11:12 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I used the Holley precisely because it is plastic...I figured the less hot aluminum to transfer heat to the incoming air the better. By itself I don't know that they are worth that much ET, but along with porting the plenum, improving flow in the airbox, etc. every little bit will add up.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 19, 2015 10:02 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
