I need some help, I have a problem...
Old Dec 7, 2000 | 05:14 PM
Dan87IROC-Z's Avatar
My car has been acting very weird as of late. What will happen is that it will kinda of hope or stumble or jump through the RPM Range. There is also a popping or knocking sound under full throttle (where it jumps and skips the worst).
I have a new alternator, battery, starter, MAF, ECM, fuel pump, fuel filter; its throwing no codes, I am out of what it could be, any ideas???
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 7, 2000 | 05:21 PM
ede's Avatar
ede
since you don't have any codes set i'd look at tune up related parts and fuel supply and volumn.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 7, 2000 | 07:07 PM
Vader's Avatar
Dan,
Just a guess, but ignition miss and lean mixture come to mind.
Since you're getting some knoching under load, you might want to consider that the distributor is not getting spark to the right cylinder all the time (cap & rotor).
Verify the ignition system first, then look at the possible causes for a lean mixture. If you have a fuel pressure gauge, a quick test of the rail pressure could be very imformative.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 7, 2000 | 09:28 PM
Thanks guys, I got my new cap and rotor kit in from Summit today, so I guess I will try that first.
L98 TPI 350 (5.7L)
Old Dec 8, 2000 | 11:58 PM
I'm putting that new cap and rotor on the car on Saturday, but any other ideas as to what it could be?
L98 TPI 350 (5.7L)
Old Dec 9, 2000 | 09:38 AM
theformula's Avatar
You said it was knocking right? Whats your timing set at? You may want to retard it if its past 10*s. Also, what octane gas are you using?
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Old Dec 9, 2000 | 04:05 PM
Yea, thats somthing I haven't checked is my timing (our timing gun is broken). And I am running some 91 octane fuel.
I did just get done replacing the cap and rotor, and it took the knock away but its still chugging and skipping through the RPM range, less than it did, but its still noticeable.
L98 TPI 350 (5.7L)
barbiek9
Sep 3, 2002 04:24 PM
FLYNLOW92rs
Aug 30, 2002 12:17 AM
Philou
Aug 18, 2002 01:29 PM
Blaze of Glory
Nov 20, 2001 10:18 AM
