Guys with TES headers take a look please
Old Dec 7, 2000 | 01:57 PM
Blade's Avatar
How did you install the oil dipstick tube ?? I cant get mine for the life of me, and there isnt enough room between the header tube and the valve cover to go trough there. I have it off to the side underneath the header tubes, but now the dipstick wont go in all the way even if I force it. How did you guys put it in ? Pics would help a lot if you have any. Thanx
Old Dec 7, 2000 | 02:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Since I dont have my car here to look I believe it goes through the headers not along the valvecover and attach it with the supplied dipstick holder. BTW your going to have to bend it in a few directions to get it right in. Tom K. Had a perfect pic of the dipstick. Thats how I learned to do mine.
[This message has been edited by Mkos1980 (edited December 07, 2000).]
Old Dec 7, 2000 | 03:11 PM
Blade's Avatar
Sigh... I got the headers used and didnt get a dipstick holder. Anyway to "fabricate" one ?
Old Dec 7, 2000 | 03:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
All you would need was a steel zip tie. it was just really a clamp that went around the header and held a loop thing fo rhte tube.
Old Dec 7, 2000 | 03:34 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
you have to swear a lot and scream at everyone around. It is a bitch and a half, if you stick to it you will figure it out. the dipstick will never work smoothly though, Ive done it twice. It neve gets easier. Just keep bending and tweaking and youll get it
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Dec 7, 2000 | 04:01 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I got mine used and didn't get a dipstick holder either. I put the dipstick back in, but since the little bracket doesn't line up with the header bolt, it's not held in place. So basically you can move the dipstick back and forth some, and it reads a quart too high, but it doesn't leak. It's pretty close to the bottom on my eternally long list of things to fix.
Old Dec 7, 2000 | 06:23 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I had the same problem with my dipstick. I had to go to the part store and get a new one and man. It seems like I spent more time trying to work that damn dipstick in the oil pan than I did on the headers. That is something isn't it?
Eric Natzke
91 Firebird 305 TBI (ZZ5 "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Dec 7, 2000 | 06:57 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Mine is held in place to the header tube with a plain old steel hose clamp. No leaks, and the arrangement is stable enough so it reads accurately.
Old Dec 8, 2000 | 04:10 AM
Pat Hall's Avatar
D_Amlee is a man after my own heart. Simplicity is so practical ain't it??? I love how Edelbrock makes all these big claims as to how much better their parts fit compared to other aftermarket suppliers. What a joke. Sometimes it almost takes an act of God to get their so called "factory replacement" carbs to fit on a stock Chevy intake as well!
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 8, 2000 | 12:38 PM
1989CamaroRs's Avatar
mine is on the outside of the header. i grinded of the bracket on it. It may give slightly inacurate oil readings but i had bent it out a little. also i had to hammer it to get it in all the way.
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
Old Dec 9, 2000 | 11:55 PM
daniel dekay's Avatar
i did mine a little like this; broke the old one off cuz it was pissing me off, i think the replacement was like 8 bucks, well worth it. did some twisting and turning and about 3 flesh wounds and a half hour later it went in and gives me fairly accurate readings. i dont remember off hand how exactly it went in (between headers and what not?) and its too cold to go check. if you must know i can take a look tomarrow or sumthin.
daniel
Old Dec 10, 2000 | 05:39 PM
Blade's Avatar
Thanx for all the input guys. Tonite I'll try to re-route it somehow, because my dipstick wont even go in the tub anymore. I'll see what I can do. :/ Nobody has a pic though ? It would help a lot as a starting point at least.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 12.9@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Old Dec 10, 2000 | 06:07 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's not the greatist pic ,, but I got mine it w/o too much hassle between the long tube from the front cyl & the air tubes. It only took a little coaxing with a nylon hammer to get it all the way in. Hope that kinda helps
Da Boid
- 4 out of 5 people think the 5th is an idiot
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1984HO
Mar 19, 2021 11:59 AM
Out-Cast
Aug 22, 2015 07:49 PM
Zeek1041
Aug 21, 2015 08:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
