How do I check codes in a Ford Truck?
Old Dec 6, 2000 | 11:14 AM
Macgyver's Avatar
It's an 88 F-150 Long bed, 351 EFI.
How do I recall stored trouble codes?
Shane McConnell
macgyver@nethirdgen.org [*]Webmaster of www.NEThirdgen.org[*]1991 RS 305 T5 15.6@88[*]1979 Z28 ZZ4/2004R (In the future.)
I'm the kinda guy you bring home to Mother.
Old Dec 6, 2000 | 05:05 PM
ede's Avatar
ede
well mac a long time ago i went to school and learned how to do it, but i think i've forgot most of it. last time i had to a bought a code reader for about 30 dollars. if i recall correctly you unplug a gray plastic plug from a harness on the left inner fender near the firewall and you can use a analog volt meter and count needle sweeps, like you do flashes on a gm car.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 6, 2000 | 05:07 PM
ede's Avatar
ede
i forgot in the future take all your ford post to www.idrivejunk.com
no offense intended to all the ford owners that come here.
1st & 3rd
Old Dec 6, 2000 | 11:16 PM
Macgyver's Avatar
Make that: http://www.ihavetofix****tyfordvehic...havebought.com
Old Dec 7, 2000 | 04:11 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
its a ford, there is no easy way.. bottom line you need a breakout box..
Old Dec 7, 2000 | 04:22 PM
ede's Avatar
ede
you don't need a break out box to read codes, unless a lot has changed since i last worked on one. the break out box is for probing the system to get readings with a DVM.
1st & 3rd
Old Dec 7, 2000 | 04:27 PM
Vader's Avatar
Mac,
Ed is correct. You can retrieve codes with an analog meter or a test light. Install a ground connection to the diagnostic terminal at the ALDL and readd the meter sweepr as "pulses". When I get to my home office, I'll post a link to the code tables and instructions.
All I can remember about the instructions is the very last line saying something about dynamite, safe working distance, and legal representation, I think...
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 7, 2000 | 10:04 PM
Vader's Avatar
Mac,
This file has common Ford error codes and retrieval instructions:
Ford Error Codes.pdf
Use at your own risk.
Later,
Vader
Old Dec 9, 2000 | 05:00 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
hmph.. i just got my info from back in the day when i was young and stupid and owned a ford product (gasp) (dont worry its in a boneyard now), everyone i spoke with told me i need a break out box and dvm to check codes...
Old Dec 10, 2000 | 09:19 AM
ede's Avatar
ede
scoob the break out box has 60, i think, holes for the leads of a DVM. when you read the codes the flow down chart for trouble shooting will say to check for XX voltage at #45 and #12. all you do is probe the 2 places in the break out box and you have your answer. i like it, quick and simple. i tihnk honda uses a similar set up. other than the cost of a break out box it's a fast easy way to check voltage. on the other hand my scanner reads all the voltage when i check for codes and such. now i'm sure we'll get a ford mechanic on here to flame me, because it has been a long time since i've done it.
ICON Motorsports
1st & 3rd
Old Dec 10, 2000 | 04:34 PM
Vader's Avatar
Mac,
Sorry for the delay - the link is working now...
Later,
Vader
Old Dec 10, 2000 | 06:10 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
ede, naw dont think we'll get any frod mechanics coming by persay.. their all too busy..
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 8, 2015 01:18 AM
