Comp Cams XE cams?
Old Oct 28, 2003 | 08:00 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Comp Cams XE cams?
Hey guys im not sure which cam i want from the XE line. ive been lookin at the XE262 and the XE268. specs for the XE262 cam are for lift int/ext .464/.470 @ .050 lift with a lobe of 114. the xe268 cam specs are int/ext .479/.490 @ .050 lift with a lobe of 114.
im goin to be using comp cams pro magnum roller rockers with a 1.5 ratio enless someone says the 1.6's will be better.
also im goin to go with a 2800 stall converter and 3.73 gears and probably an edelbrock rpm air gap intake or Dart air gap style intake. and if i have the time or money ill either have the heads ported or buy the world products S/R torquer heads but those would be later. cam, gears, converter are what im really focusing on.
Old Oct 28, 2003 | 08:58 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Take a look at this post from just a couple days ago..... it's amazing what searches can do!
https://www.thirdgen.org/techbb2/sho...hreadid=206802
Old Oct 28, 2003 | 09:40 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah but thats a 355 motor that one of those cams are goin into, im sticking with the 305 till it blows
Old Oct 29, 2003 | 12:12 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I havent been impressed with the XE cams in SBC's they just dont do what they claim to be able to.
If you want a comp cam the your best bet will be either 260H or if your getting the gears done at the same time a 268H would be the max I'd use. Nothing like over caming an engine and ending up with less power then you started with if ya know what I mean. Persaonlly I would look into a Xtreme 4X4 cam 305's love tq cams.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
