bad pushrods and lifters?
Old Nov 1, 2003 | 01:30 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
I decided to start taking the intake and heads off the old motor today that's still in the car. I noticed that no rockers were broken and none of the arms were loose (was checking for collapsed lifters). Out of curiosity, I decided to loosen all the rockers up 1/4 turn and start the car. When I did that, it sat there and idled till I shut it off. Before, it was only idling for a few seconds before it died. Also, the loud whistling noise I was hearing was suddenly gone. I now believe it was coming from a bad seal at the rear of the valve cover gasket on the driver's side. I examined everything while the car was running and noticed that both springs on the #1 piston were being flooded with oil. However, the rest of them were either not doing that or had very little oil being pumped up through the pushrods. My first thought is to clean all the spare pushrods I have from the new block and replace the ones in the car with those, as well as all the lifters, just to be safe.
What would you guys say? Opinions?
Old Nov 1, 2003 | 02:46 PM
ede's Avatar
ede
the oil or lack of oil isn't a big deal i wouldn't do anything more than put it back together and see how it runs
Old Nov 1, 2003 | 08:47 PM
redrummer's Avatar
Engine: 5.7L L98
I've got them all tightened down where they don't make any noise at all. Tomorrow I'm going to back them off one by one and listen for the clacking sound and adjust them that way. Before, they were all making noise and I couldn't tell which ones were clacking and which ones weren't.
The method I used was found in Chevy High Performance. It said to adjust in some strange manner. If you're adjusting the intake valve, rotate the motor so the exhaust is just starting to close and vice versa. After I did it that way, the car ran for about a day and decided it only wanted to idle for a few seconds and die after I cranked it.
Old Nov 2, 2003 | 12:06 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You wouldn't mind letting me know about that CHP procedure, would you?
Old Nov 2, 2003 | 06:43 AM
redrummer's Avatar
Engine: 5.7L L98
Sure, I'll track it down this afternoon and scan it.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Sep 16, 2015 12:40 AM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
