Correct torque of roller rocker arms
Old Nov 1, 2003 | 04:55 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I developed lifter tick, and got some bad information on the correct torque calibration for each arm. What should the correct callibration be for stock 350 heads.
Old Nov 1, 2003 | 05:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Tighten until the "click" stops, then 1/2-1 more turn...prefernces vary like bellybuttons.
Old Nov 1, 2003 | 06:03 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
See, that's the thing. There never was a 'click', it just kept tightening.
Old Nov 1, 2003 | 06:50 PM
Morley's Avatar
There is no "torque" to SBC rockers, it is a fully adjustable system. You back off the nut until it just starts ticking, tighten till it just stops then go 1/2-1 turn more (tightening).
Old Nov 1, 2003 | 07:25 PM
25THRSS's Avatar
What they mean is tighten the rockers down to zero lash as best you can guess. Then start the engine with the valve covers off and back the rockers off slowly until they click, and tighten until the clicking stops. Then go about 1/4 to 1/2 turn past that.
Old Nov 1, 2003 | 11:43 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
i do mine with motor off... Tighten the nut until I feel no upward/downward motion in the rocker arm... then I do all one side, then the other side (yeah tahts alot of turning the engine over) then a 1/2 turn more... Never had any problems with mine but noone seems to like doing it this way... I would never mess with the vavle train with the motor is running but that is just me..
Old Nov 2, 2003 | 01:34 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I do them like Hydric above does. I disconnect the coil and bump the engine over to 0deg and #1 is in firing pos. I do Int #1,2,5,7 and exh 1,3,4,8. Then I bump the engine around to 0deg again (#6 fire) and do int 3,4,6,8 and exh 2,5,6,7
Old Nov 2, 2003 | 09:09 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Aight, thanks for your replys. I got my car running good again. Thanks.
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
