battery?
Old Dec 14, 2000 | 03:39 PM
HMD's Avatar
HMD
battery?
is it possible for a low battery to affect the preformance of your car?
88 GTA Notchback
350 TPI, T-roofs
Fully loaded, Digital dash
firebird red
Old Dec 14, 2000 | 04:06 PM
mtx28's Avatar
quite so, if your combustion process isnt happening completely, or isnt burning as fast as it should, then your power will be lower
Old Dec 14, 2000 | 04:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The alternator should power the ignition circuits when the car is running, so I don't think a simply partially discharged battery would affect performance. If the battery is damaged in some way, such as by an internal short in one or more of the cells, then it could place an unusual load on the charging system and have a negative impact on performance.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Old Dec 15, 2000 | 12:16 AM
HMD's Avatar
HMD
I have found that when i leave the charger on overnight the car runs better for a few days. Also when i left the car for 5 days the battery was dead>
Old Dec 15, 2000 | 01:32 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sounds like it might be a bad battery then, run it over to your local Crappy Tire and they should test it for free.
Old Dec 15, 2000 | 04:49 PM
HMD's Avatar
HMD
cool, thanx for the help
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
