Too cold!!!!!!!!!!
Car: 88 Camaro IROC
Engine: 5.0 TPI
Too cold!!!!!!!!!!
Any tips on how to get my 88 iroc 305 TPI to warm up faster. Particularly in the engine compartment. It's really getting cold around here. I have a 160 degree thermostat should i switch it out for a new 180 degree?
Re: Too cold!!!!!!!!!!
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
a 180 - 195* thermostat
theres no reason for you to even have a 160 in there.
all that the 160 thermo is going to do is not let the engine warm up.... its going to stay at 160 and niether you or the engine will be warm...
Sorry i meant i want it to get warmer in the passenger compartment faster.
Car: 88 Camaro IROC
Engine: 5.0 TPI
i was told that a 160 would keep the engine cool in the summer. I was having overheating issues when i was sitting in traffic. It helped them but now it's just freakin cold. It's in the 50's during the day and low30's at night should i go 180 or 190 or maybe even 195?
Car: 91 Camaro Vert
you need to put the proper thermostat back in, no lower then about 180 or so and next summer, fix whatever cooling problem you have. there are thousands of other 3rdgens that arnt overheating with that thermostat.... you have some other problem.
a cooler thermostat is just a bandaid. it wont keep the car cooler, it just gives it a cooler starting point before it overheats...taking longer to overheat.
its still not going to keep you from overheating if you sit there long enough.
... now it's just freakin cold. It's in the 50's during the day and low 30's at night ...
Car: 1989 C4
Axle/Gears: 307
I use a 195* t-stat for colder weather. I could live with 50* days fairly easy. Last year I ran a 180* until febuary. One night on a drive across town 0* -25* with wind chill my temp guage dident even move, froze my b utt off. Went 195* a drove comfortable until april. temp guage on cold days hung around 200* with the 195.
Car: 88 Camaro IROC
Engine: 5.0 TPI
I'm used to a dry cold, used to live in wyoming -20's but now i'm in washington and trying to get used to the wind and humidity
Car: 2006 Silverado 1500
Engine: 5.3L
that's not terribly cold, but a higher temp thermostat is pretty much the only way to fix that issue. or just not be so impatient. 160 stat will give heat, just not alot at once. i've ran them in michigan in most everything i've owned, but running the fan on any high speed is useless and on true cold days, it'll only take the chill off.
Car: 91 Camaro Vert
just to contrast....
i run the stock thermostat and ive re routed the heat to all pour out by my feet... so even when its in the 40s, i can still have the top down on the vert and cruise at hwy speeds. the hot air gets sucked right up over me....
Car: 91 Camaro Vert
Originally posted by Gumby
Did anyone say by a remote starter yet??? Just leave the heat on when you go in the house.
Matt
Matt
just cross the wires so it still thinks its in park, shift into drive and go!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by MrDude_1
**steals gumbys car**
Matt
Course all you need is a good flat head screw driver and any thirdgen is yours.
Car: 91 Camaro Vert
I got a stick so it even easier.
Matt
Matt
and the flat head screwdriver trick only works on non vats cars....... and even then its not the best way to steal a older GM car.... cracking the other side of the column is.
ramicio
Sep 28, 2015 01:18 PM
