Glowing exhaust
Old Dec 16, 2000 | 01:27 AM
Kage86TA383's Avatar
Glowing exhaust
87 TA (383\TPI\EB cat-back) with SLP stainless headers (AIR) and new cat... the entire length of the exhaust glows cherry red and smokes even at an idle. The glow goes al the way back to the muffler. The engine starts and idles well.
My brother (allegedly a mechanic) "fixed" the car, but it didn't do that when I brought it to him. I understand that this is a "lean" condition issue... but I put it all back together after it was apart for a long time... could I have hooked up the smog air injection wrong? How else could a FI engine with less then 50 miles start acting this way?
HHHeeelllpppp!
Old Dec 16, 2000 | 01:55 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Did you check your timing? That is usually thr #1 casue of glowing red exhuast.
Kat
90 RS 305 TBI A4
Dumb ***/**** poor/orginating memeber of the infamous NE Crew
Time to see, believe this in me,This pain that i feel deep inside
Old Dec 16, 2000 | 11:51 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If your friend messed with the timing he may have forgotten to disconnect the brown wire located near the blower moter on the passenger side (the manual gives a more accurate description). This is a MUST when adjusting the timing.
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Old Dec 16, 2000 | 03:33 PM
CamaroMike's Avatar
Running too rich will make the exhaust glow more often than a lean condition.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Dec 16, 2000 | 03:45 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Running leaner is always hotter. Also, if you were to ceramic coat or Jet coat the headers they will not glow. The stainless doesn't allow the heat to dissapate, so they get even hotter. Like the hot rodders that crome their radiators, or paint them. Then they wonder why they run so hot.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 16, 2000 | 04:36 PM
The stainless headers aren't coated. And the exhaust runs so hot at an idle that it's smoking for it's entire length (to the muffler) and you can actually see the exaust pipe glowing all the way to the muffler.
This car has had some elctrical problems (the reason my bro "fixed" it. I haven't been able to contact himto find out about the timing... it wasn't doing this when he laid hands on it.)
At this point, I know to check the timing (disconnecting the brown wire) are there any other ideas?
86 TA/vette 383TPI/700R4/MSD 6A/SPL headers/edelbrock cat back/an angry squirrel.
86 Fiero SE 2.8V6/5SPD/turbo/2nd angry squirrel.
Runs on peanuts!
Old Dec 16, 2000 | 06:44 PM
CamaroMike's Avatar
Would you just listen to me!! Yes a lean engine will run hot and the exhaust hotter BUT............... if you have raw gas being dumped into the exhaust stream and burning then the exhaust will glow damn near to the end of the muffler. A lean vehicle will only make the headers or manifolds glow. You said your brother messed with some wiring, right. Maybe for whatever reason the injectors are staying open too long or the ECM is fried, dumping raw gas into your engine. Find out what the hell your brother did and reverse it if possible.
[This message has been edited by CamaroMike (edited December 16, 2000).]
gta892000
Aug 11, 2019 11:16 AM
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
andy74
Sep 3, 2015 08:41 AM
