Fuel pressure regulator
Old Nov 5, 2003 | 04:35 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Pt# 510-512-501
http://www.jegs.com/cgi-bin/ncommerc...41&prmenbr=361
This is the one I would need right? The holley with the easy to turn **** as I read when I searched. Just wanted to make sure before I purchased, thanks.
Old Nov 5, 2003 | 10:37 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
http://www.jegs.com/cgi-bin/ncommerc...18&prmenbr=361
The one you had pictured is mounted on the vehicle fender or firewall. If that's what you are looking for, great. However if you are looking for an adjustable fuel pressure regulator which installs on top of the stock location regulator, the one I've linked to is more like what you need. The Crane is a good one, so is the TPIS version or the Accel. As you can see from the pics it also comes with a gasket set which you will need to get at the stock pressure regulator.
Old Nov 5, 2003 | 10:40 PM
MdFormula350's Avatar
that holley one is correct, just the picture is not right.
that part number shown is the one for tpi and will have the **** for easy adjustment.
"Product images may differ from actual product appearance."
Old Nov 27, 2003 | 01:57 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Wow, ordered that one. Got it today, wrong one, made for a ford. Then the lady at Jegs is telling me they don't make mistakes.
Boo to the mentally challenged.
Old Nov 27, 2003 | 09:23 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Understatement Of The Year. Tis not true. they do make mistakes. not only did they send the wrong motor mounts but, in the wrong color as well(poly mounts). <---Jegs
Old Nov 28, 2003 | 01:23 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I just finished making mine adjustable. I couldn't see spending $60 on one I can make in 10minutes. Here is a How To if you want to modify yours.
http://www.gmtips.com/3rd-degree/dox/tips/afpr/afpr.htm
Later,
Charlie
Old Nov 28, 2003 | 05:55 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I think this is the Holley AFPR you're looking for....
http://store.summitracing.com/partde...LY%2D512%2D501
Just bought one myself
Old Nov 28, 2003 | 06:55 PM
Car: 1988 IROC-Z
Engine: 427 SBC
5.0L TPI only Is this the one with the easy turn **** too?
Old Nov 28, 2003 | 07:18 PM
Car: 92'Camaro RS
Engine: a loud one
5.0......5.7 liter.......same deal, fits both...yea look on the top of it, you can see a big dail to turn it to adjust. I was looking also at the BBK APFR for 59.99. Cheaper, but you have to change out some parts from your old regulator to make it work.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
