@!#%$!#@$%@# rusted cam
Old Dec 16, 2000 | 11:43 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I've been out of town and I just came back and went to my shop to check up on things...apparently the roof sprange a leak and dumped water over all my @#$%@%$ cams...there is surface rust on all the surfaces. If I scotchbrite this off will they be alright or are they junk?
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 17, 2000 | 12:08 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I suppose it depends on how long it was. If they're rusted enough to cause pitting, I would be hesitant to use the cam, but if it will all come off with scotch brite, it will probably be ok.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Dec 17, 2000 | 09:38 AM
ede's Avatar
ede
yeah i agree if they clean up with scotch brite i wouldn't worry about it. you wouldn't want to use anything that left marks that would cause wear.
ICON Motorsports
1st & 3rd
Old Dec 17, 2000 | 10:22 AM
Vader's Avatar
IROC,
Are the cams rollers or flat tappets? The surface rust on a flat cam might not be a big issue, since the first twenty or so minute of operation should polish the lobes rather nicely. A roller cam might not be as forgiving, but remove all the rust first and have a closer inspection.
Just a hint: Storing spare parts in original cartons and/or in plastic bags can prevent a lot of this kind of mishap.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 17, 2000 | 05:39 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I would guess it wouldn't cause many problems on a roller cam either, because the roller is going to, um, roll over it anyway.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 17, 2000 | 10:50 PM
irocz's Avatar
Car: '87 IROC-Z
It's a roller cam alright...although I have a couple of pontiac solids as well. I keep all my stuff in the original boxes, but the bag was not on the cam when I got it. I think I'm going to take all of them to a machine shop and have them polish them. thanks
my86bird
Oct 23, 2015 12:20 PM
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
