Idiot ECM can't handle winter
Old Dec 18, 2000 | 03:50 PM
jrr's Avatar
jrr
Every winter, since I bought my 1985 Camaro w/305 and auto, it will idle fast even when the engine is warmed up. No codes, the temp sensors are O.K. (I think). The resistance of the temp sensor goes down as the coolant temp goes up but what resistance should I see at 190'-200'?
The TPS is O.K. the choke is open and the linkages move freely, but the ECM-controlled throttle actuator won't let the throttle come down to a normal idle. I have a 192' thermostat but it still idles fast. Only when spring comes around and the temps get above 70', then it will idle nice and slow.
Any ideas?
Old Dec 18, 2000 | 04:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Exactly the same problem with my 85 IROC manuel. Along with jrr, I'd appreciate some suggestions.
JamesC
thunder57
Nov 7, 2015 02:28 PM
tmellott89
Oct 14, 2015 02:06 PM
ndndndnd
Sep 28, 2015 08:00 AM
efiguy
Sep 27, 2015 01:30 PM
mfp189
Sep 27, 2015 09:25 AM
