Non thirdgen but desperate
Old Dec 19, 2000 | 05:40 PM
foo02's Avatar
Ok...once again i come back with a 3rdgen question..but this pertains to 3rd gen Nissan maxima
Symptoms--177k miles, valves tick on and off untill warmed up, sounds like rod knock untill warmed up. Motor had lots of sludge in it, which i pulled oil pan and valve covers and got some(most) out. has clean oil and a factory oil filter on it. Sometimes it takes up to 5 sec to it to build up oil psi on a cold start.
Dont know oil psi due to car only having a dummy light
Now...what do yall think..?
Old Dec 19, 2000 | 06:08 PM
ede's Avatar
ede
trade it for a chevy. it doesn't sound good, but you need to fit a mechanical gauge on it somewhere to check the actual oil preasure.
ICON Motorsports
1st & 3rd
Old Dec 19, 2000 | 08:03 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Did you clean out the oil pick-up screen??
These have "HLA" type lifters. (hydraulic lash adjusters)
It is very common for these to start acting up in high mileage applications. They are really small lifters in the rocker arms. They plug up real easy.
Belive it or not a couple of dealers around here are putting "Rislone" oil treatment in them and it is cleaning them out.
I just did one with the same symptoms as yours and it worked.
I would try a jug of rislone with an oil change using 10/30 or 10/40, stay away from thick oils, this just makes it worse.
I personally don't like any additives but you have to do what you have to do. Those HLAs are expensive to replace.
This is taking for granted that the noise you hear is valvetrain and not a rod knock.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited December 19, 2000).]
Old Dec 19, 2000 | 08:42 PM
foo02's Avatar
yeah they're 45 bucks a piece from the dealer, still expensive from a parts chain(about half that). Iv tried Rislone and it didnt do anything
would low oil pressure cause these symptoms too?
Old Dec 19, 2000 | 10:21 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Yes.
I would do as stated above and put a mechanical gauge on it.
See if you have anything left to worry about.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
