Will these pistons fit?
Old Nov 11, 2003 | 07:36 PM
bes217's Avatar
I am building a 400 and was wondering if these pistons will fit with my Pink rods that I I got out of a 350 engine. It says that they are for a 5.7" rod which is what the 350's have. So I am assuming that they will work. I hope they do because I want something with lower compression so that I can run a supercharger later on.
http://store.summitracing.com/partde...2F30&view=2047
Old Nov 11, 2003 | 07:49 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
They will if you are building a 377.
With the 400 crank they might stick out of the hole just a little bit.
Old Nov 11, 2003 | 08:23 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
no dice...
Old Nov 11, 2003 | 08:30 PM
bes217's Avatar
So where can I find some reasonably priced lower compression forged pistons for my 400. I am correct when I say that a 400 uses a 5.7" rod, right? Doesn't it also use a 3.75" stroke crank, and a 4.125" bore?
Old Nov 11, 2003 | 08:35 PM
400 uses a 5.565" rod, not a 5.7
Old Nov 11, 2003 | 08:38 PM
Car: 87 Firebird
A 400 uses a 5.565 rod which, not by coincedence, is shorter by half the difference in strokes between the 350 and 400 crank. 350's use a 5.7 rod.
edit- B+B beat me to it.
Old Nov 11, 2003 | 08:40 PM
bes217's Avatar
Maybe something like this? I will want something forged and lower CR but theoretically it will work, right?
http://store.summitracing.com/partde...5P30&view=2047
Old Nov 11, 2003 | 08:54 PM
Car: 87 Firebird
Those look like they have the right pin height.
Old Nov 11, 2003 | 08:59 PM
no they dont. read the description. they are for a 377 (3.48" stroke/5.7 rod) or a 400 using STOCK 5.565" rods. they will not work on a 5.7" rod 400. you'll end up with pistons hanging .135" out of the hole.
Old Nov 11, 2003 | 09:01 PM
bes217's Avatar
I am thinking maybe these and using aftermarket forged rods:
Old Nov 11, 2003 | 09:31 PM
those arent rods, those are pistons...
Old Nov 11, 2003 | 10:02 PM
bes217's Avatar
I know that is why I said "maybe these (pistons) and using aftermarket forged rods"
Old Nov 11, 2003 | 10:08 PM
use a piston specifically designed for a 5.7" rod. it will reduce wear in the cylinders, as well as making the engine less prone to detonation.
Old Nov 11, 2003 | 10:14 PM
Car: 87 Firebird
I think he found the right pistons in his 8:40 PM post
Old Nov 11, 2003 | 10:16 PM
i'd be careful supercharging with a CR that high...
Old Nov 11, 2003 | 10:50 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Those second pistons you picked at Summit are the ones you want.
Specifications:
* Bore: 4.155 in.
* Stroke: 3.750 in.
* Rod length: 5.700 in.
Sounds like what you have, right?
BackInBlack is right about the CR. Be careful how much PSI you run.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
