Need help with my cam!!!
Old Nov 11, 2003 | 10:14 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Can someone shed some light on the cam i have in my 455 pontiac i have no clue about cams can somone tell me about it and also how to understand all the numbers i look at my cam card and am completly lost. Will this give a good sound at idle with flowmasters?
Also will this cam do good with a Torker 2 intake and 750 Speed Deamon Carb?
its made by Ed Iskenderian the cam card reads
Grind Number 256 HYD Super Cam
Intake Timing ------------------------ Exhaust Timing
Open 22 BTDC ---------------------- Open 66 Before BDC
Close 54 After BDC ----------------- Close 10 After TDC
Cam Lift .281 ------------------------- Cam Lift .281
Valve Lift .425-------------------------Valve Lift .425
Intake After ------------------------Exhaust
Open 5 TDC----------------------- Open 39 Before BDC
Close 27 After BDC---------------- Close 17 Before TDC
The above Timing is Checked at .007 Lifter Rise
Old Nov 11, 2003 | 10:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
This is a reletively mild street cam in a pontiac motor.
It's basicly a stock replacement cam.
It will have a smooth idle. The power band is from idle to 4800rpm.
Not the best choice for horsepower with a Torker II pontiac intake.
For that you'd want a little bigger cam.
Like and Isky 280 MEGA CAM. You can find the specs for your cam and other ISKY cams at www.iskycams.com
Old Nov 11, 2003 | 10:48 PM
FAST RS's Avatar
Well i guess when i put different heads on the car i want the edlebrock heads. I will replace the cam as well. Hey anythign is better then the 350 that i had in the car that destroyed it self.
Old Nov 11, 2003 | 10:57 PM
FAST RS's Avatar
I was hopeing it was a deacent cam. Dammit now someday i will have to change the cam. Any idea what kinda hp i should be pushing in it?
455
Port and Polished 7m5 heads
Trw Forged Pistons Bored 30 over New rods Stock crank.
Torker 2 Intake
750 Speed deamon
Super Comp headers
It should be a fairly deacent engine for the street?
Old Nov 11, 2003 | 11:08 PM
F-BIRD'88's Avatar
You can get a good idea of how much horsepower you're making by running your car down the drag strip and getting a et time slip.
The MPH at the end of the quarter mile indicates your horsepower.
I'd say about 350/ 360 gross flywheel HP.
Old Nov 11, 2003 | 11:18 PM
FAST RS's Avatar
The engine is not in the car yet. Ive waited 4 years to drive the car i bough tit after an accdent took 2 years to find parts got it running drove it up the grade 30 mins after finaly getting everything good and running. It threw a rod. Now its getting a new engien tranny suspension.....
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
