What cam?
Old Nov 12, 2003 | 07:46 AM
racewrench's Avatar
Car: 1992 Camaro RS
Engine: 305 (406 swap coming)
What cam?
I am working on a 1987 Iroc 305 tpi with a 5 speed. can anyone tell me what the stock cam numbers are for this car?
Old Nov 12, 2003 | 02:53 PM
Damon's Avatar
Check out the FAQs and tech segments of this board. They have cam specs listed for various factory f-body applications.
If memory serves it's around 201/207 duration @ .050 and around .410-.420 lift. That's the "aggressive" TPI cam that 5-speed 305 TPIs and all 350 TPIs got. Stock 305 TPIs that were paired with an automatic trans often got what is referred to affectionately as the "peanut cam" with even milder specs.
Old Nov 12, 2003 | 03:26 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The blind leading the blind again.
Just messing Damon.
It's actually under the Tech Data, near the bottom of the page.
https://www.thirdgen.org/newdesign/tech/techdb.shtml
305 5spd / 350 AT (LB9/ L98) .....
GM part #14093643*
Lift --- .404" Int/ .415" Exh.
Duration @ .050" 202* Int/ 207* Exh.
Lobe Seperation... 114.5*
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
