anyone had this problem installing Headers?
Old Dec 18, 2000 | 06:05 PM
dtpmike's Avatar
When taking the studs off of the exhaust manifold the stud breask off? What other types of problems may I encounter? Or is this an easy mod(Headers)?
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from MrMikes.com
Old Dec 18, 2000 | 06:29 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
No problems just a bunch of cuts. You might have to jack the engine up on the driver's side to wedge the header in.
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, Holley Street Dom intake.
Old Dec 18, 2000 | 08:12 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well its entirely possible you might run into prob with theexhaust manifold bolts breaking, but its always a crap shoot with anything that has been threaded in for years on end
Steve
Old Dec 20, 2000 | 10:31 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Try putting on the passenger side from the bottom. Also, I might be wrong but I think that I took the starter off. Make sure that you jack the car up really high for clearance. Use jack stands
rocn7roc
Sep 21, 2021 02:16 PM
Wesly_66
Aug 26, 2015 09:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
drathaar907
Aug 6, 2015 04:20 PM
