64 vette intake vs. modern aftermarket
Old Nov 13, 2003 | 04:45 PM
lunatic_magnet's Avatar
Car: 87 camaro
Transmission: 5-speed
question for anyone who feels like answering...
i scored a good running motor for my 87. its a mix of different parts. it is a 69 block with 70's heads and a 63-64 vette tall aluminum intake on it.
should i keep the vette intake? its pretty weird looking with the oil fill neck shooting out the front of it. i think i kinda like it. but would i be better off with a newer aftermarket intake than a 60's gm product? or should i not mess with whatever combo someone has built?
GM 3844461 intake
Old Nov 13, 2003 | 06:06 PM
ede's Avatar
ede
you can buy better intakes and you can get enough money out of that intake to buy several aftermarket intakes
Old Nov 13, 2003 | 06:10 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
You can block off the oil filler opening with a frost plug if necessary.
Unless you're running a tall hood you probably won't be able to run that intake with any kind of decent air filter - the manifold is probably much taller than a stocker or Performer.
I think ede is onto something, put the intake on e-bay and it may buy you an intake manifold that will fit under your hood and perhaps a pile of other speed parts.
Old Nov 13, 2003 | 06:40 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yep, its worth some money to a resto guy, see what ya can get for it, also does the carb sit sideways on that? never seen openings like that..
Old Nov 13, 2003 | 06:46 PM
Car: 87 camaro
well i did a quick ebay search... there are 2 of them up there right now and neither has a bid on it. lowest one starts at $125... doesn't look like anyone's buying at the moment.
i have a cowl hood so i'm not too worried about the height. i actually have an adapter plate for the edelbrock carb and air cleaner spacers on the car right now... i really dont think that intake would be a problem on my car.
the holley that came on the motor sits on there the way it normally would. i know i was scratching my head when i pulled it off and saw that weird opening pattern... i thought maybe it was originally 4 holes that someone grinded out but *shrugs*
Old Nov 13, 2003 | 06:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Performance wise it was a good intake compared to the other ones avalible durring the 60's. BVy todays standards I doubt it would flow as much as a standard performer and thats only a tad better then stock. But yea its a nice find and will make a restoration owner very happy and they will probably be willing to drop a chunk of change on a OEM square bore intake. I wouldent doubt you getting $500 for it on ebay.
89RS, no the carb mounting is standard square bore, some aftermarket intakes still use the open port like that on one side.
Old Nov 14, 2003 | 11:05 AM
89RsPower!'s Avatar
weird, whats the reasoning for it?
Old Nov 14, 2003 | 01:12 PM
ede's Avatar
ede
i saw what i ithnk was a l79 intake at a car show last week, guy turned down 300 dollars for it
Old Nov 14, 2003 | 05:37 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
A Performer or RPM will definitely outperform that old Vette intake.
On HP/TV they replaced an old 69 or 70 Chevy big block intake and carb with modern pieces. The increase in hp was HUGE ... around 100 hp or so.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
