Swap Crane 2032 cam for LPE 219 & 1.5rr for 1.6rr???
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
I have the superram, 2032 cam and Crane gold 1.5 rr w/ Crane chromemoly pushrods.
I can pickup the lPE 219 cam on ebay for $250.00, get some 1.6 RR and pushrods...sell my current setup on ebay or elsewhere and be.......
Happy??!?!?? or what???
Should I...should I NOT....should I invest in a higher stall torque converter and drag radials first???
What to do?? HELP!!!!
Thanks!
Marty
Thanks!
Marty
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
A convertor will help more than the cam swap. You may have to change springs with the 219, it calls for more seat pressure.
Get a convertor.
Get a convertor.
Car: 88 Formula 350
Engine: 357
yes I would have to switch springs. But if I swap out the rockers too maybe it wouldn't be that big of a pain...
Thanks for the reply
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'd get the drag radials and a good converter, 2400-3000 stall, depending if you plan to end up w/ the LPE 219 or not. You can always swap cams later, the converter and drag radials should help more though.
See what you run with the tc and dr's, if you aren't satisfied, then try a cam swap.
1988iroc350tpi
Aug 14, 2015 07:52 PM
